C'Mon............
  • C'Mon............
    Lets talk drain cleaning
    Re: C'Mon............
    Drum or sectional?
    AllurePlumbing.com
    • leak detection
    • drain cleaning
    • utility locating
    • conductor fault locating
    • and other specialties.
      Originally posted by Gettinit View Post
      Drum or sectional?
      Both !!!
        Kinda irked me when I couldn't get a toilet cleared.
        Big hammer later showed a toothbrush was lodged deep inside.
          The K-60 beats any drum any day....there ya go....is that good enough?
          Derek
            Were you using a drophead or bulbhead toilet auger ?
              Is that why you sold yours ? Too much machine for you
                Yeah...I like a challange in life...so doing things the old fashion way is the way to do it.....
                Derek
                  Bulb. I have one auger with the end of the bulb bent out into a hook that usually grabs these things.
                  Ya win some ........
                  Will a drop head do anything different? I have no trouble getting through the toilet.
                    I would think a drophead auger would have snagged & pulled it out. But then again chit happens
                      Why you gotta hide the truth
                        I have a regular bulb head that I pulled the spring out on the first few rounds and it does great with retrieving pens and the like. The drop head would likely do it but the pulled spring grabs and holds it better I think.
                        AllurePlumbing.com
                        • leak detection
                        • drain cleaning
                        • utility locating
                          Drums have to be better thats all i got
                            Both !!!
                            The one that works best for you,I mostly use K-60,K-50,K-1500. have not used the K-750,K-6800 or the K-380 in over12 years.
                            If I keep eyeballing the very good posts on drums,I just might purchase new cables and throw my back out again loading and unloading.
                            Course it might prove to be practical.
                              Anyone camera inside of toilets?
                              Seems like a bit of overkill but there's a SeeSnakeĀ® micro™ Inspection Camera I can pick up
                              cheap. Will it push through?
