Jetter Question
  • Jetter Question
    I've got the JNW Big Brute. 4000 psi 9 gpm with 100 gallon water tank. I'm relatively new to jetting so i don't know all the tricks. I have a 300' / 3/8" hose on the jetter and a 200' 3/8" hose on the remote reel with a shut off valve on it. Majority of the time I'll use the remote reel. My question is, if I have the psi and pressure cranked all the way up and turn the shut off valve off on the remote reel while I run back to the jetter to turn the pressure down or to check the line with the camera, will that cause any damage? I haven't done this yet as Im afraid it might damage the pump. I always leave the jetter on the truck which can be a couple hundred feet away sometimes.
    Would a foot pedal be a better option for those situations or does it work in the same sense as the shutoff valve?
    Re: Jetter Question
    won't damage anything because your unloader opens up and cycles the water back into the tank. Congrats on the purchase.
      Re: Jetter Question
      Bens 100% right. The 100 gallon tank allows for cooling of the water being circulated. If this were a cart jetter without a holding tank, then after a couple minutes the water will get too hot and damage the pump packings.
      Much safer with a foot pedal or spray wand then a ball valve. Something happens and you pull the hose out too far, you'd wish you had a spring loaded foot valve.
      Another thing is 500' of 3/8" hose is a lot of pressure drop at 9gpm. I park on the street and rarely need more than 300' from a rear yard.
      I'd buy a 100' hose to give you some options.
      Rick.
        Re: Jetter Question
        Thanks gear.
        Rick, do you mean 100' to go from the jetter to the remote cart? Then have 200' on the reel?
        I ordered a foot pedal earlier today. Ill try that in place of the remote valve.
          Re: Jetter Question
          Its always best to use the least amount of hose. Its also cheaper to replace a short length than a 300' section.
          For my 3/8" hoses, I have a 300' reel I rarely use. Another 100' section on the same reel and then 2-100' hoses and a 75' hose. Any can be used as a jumper or a jettter hose.
          1/2" is a 500' continuous secton, then some other shorter hose. 100 & 200'.
          1/4" reel is a 150' and 100' on the same reel. Then other loose combinations in the trailer.
          3/16" are 100'
          1/8" is both 100' and 50' sections.
          Then plenty of adapters, reducers and quick connects between the hoses and jumpers.
          Glad you went with a foot pedal. Hopefully a properly sized one for psi and gpm.
          Rick.
            Re: Jetter Question
            I have a Big Brute 4000 psi ( really only puts out 3600 psi ) 6 gallon cart jetter, it doesn't cut roots that great. But works good on other problems. How does yours do ? How about some pic's, do you tow it around or load it up in a van ? Thinking I need a larger size.
              Re: Jetter Question
              Rat, have you tried a root ranger?
              With your specs 3600, 6gpm, a root ranger will make pulp out of the roots.
              The trick is to know where your roots are located and then focus your cleaning at those marks.
              Rick.
                Re: Jetter Question
                roots out....4gpm 3500 psi.....gotta know what to do with what you got. Let me know if you have specific questions.
                  Re: Jetter Question
                  I keep it mounted in my lining and drain cleaning truck. You must have the Bruiser. I have the Big Brute. I used to pay a guy $300 to jet the roots out with his Spartan trailer when I do my sewer linings. Since I've had my jetter I haven't had to call him to remove them now. I haven't come across a set of roots that I couldn't get through. I have the warthog, root ranger and the root rat. Haven't used the root rat except for two times. I normally go in with the warthog for a few passes then check it out with the camera then hit the spots I missed with the root ranger. Normally jetting takes me 1-2 hours when removing roots. I use it strictly for sewer ling to remove roots so I haven't used it in grease or restaurants.
                    Re: Jetter Question
                    Rick I have the root ranger and it does a lot better than the wart hog. Last job was a small root ball in a dry 4 inch sewer about 75 in, I knew the RR would blast it out but I wanted to try the wart hog. 3 passes and no go. The RR did the job after 3 or 4 passes. I took it into Plumber Warehouse and had the nozzels check and they said they were ok. Not sure what size I need. Sierra thanks for the pic's are you sure that white water tank is 100 gallons ? What is the black tank for ?
                      Re: Jetter Question
                      The small white tank on the jetter is a12 gallon buffer tank which I rarely use. The black tank is the gas tank. The 100 gallon tank sits at the back of the truck behind the green generator.
                        Re: Jetter Question
                        More is always better in my book. You don't need more,, but more would be nice. 9gpm 4k psi is a very good size machine. Our 6gpm 4k has us wishing we had more sometimes. Oh well. Smile
