sharktooth quiz
  • sharktooth quiz
    What size are these cutters?
    Roots beware of the C snake with shark teeth.
    Re: sharktooth quiz
    5" and 8"
      Re: sharktooth quiz
      Since im not an expert in carpet fibers, I think ill pass on scaling the cutters.
      Rick.
        Re: sharktooth quiz
        I think I know what you're getting at. I believe they both started out the same size (either 6" or 4"). The one on the right is just bent. Looks like you hit an offset or some other maligned pipe connection. I've had that happen to my cutters occasionally.
          Re: sharktooth quiz
          This also happens to my Spartan type bits when starting in 4" cast then eventually entering a 6" main. That's why I love the HD Eel bits, no way that's going to happen.
            Re: sharktooth quiz
            Right on Swade Plumbing.
            I was going back and forth over a hard spot and it did not feel right so I started pulling back out. There was a lot of resistence on the cable so I thought it must have been roots. When the end came out there was nothing but an enlarged cutter. My 6" cutter is now a 7" cutter. I thought it was funny that a 6" cutter can get stretched in a 6" pipe.
              Re: sharktooth quiz
              Offset for sure.
                Re: sharktooth quiz
                Was the 6" blade actually 6" when new ? Some manufacturers under size them up to an inch or more.
                  Re: sharktooth quiz
                  I have check the 6" cutters a few time and they are 6". Sometime a little over or a little under. I bought a 5" cutter that was 5.5 inches. I buy ridgid cutters and I check them once in awhile and they are pretty much on. They are not extactly the same every time. There is a little variation.
