Jetter pump oil white????????
  • Jetter pump oil white????????
    I have an AR 4000 psi/4gpm direct drive pump on my jetter. I was using it to pressure wash my house the other day and noticed some water dripping out of the pump case. Soon after, I noticed smoke coming from the oil cap. When I looked inside, the oil looked like it water bubbling and now it's white.
    Is this the main shaft seal that leaking?
    Re: Jetter pump oil white????????
    more likely the plunger packings.
    white is water and the water mixed with the 30wt. oil overheated to make steam.
