I had a new batch of shirts made i have a question ?
  • I had a new batch of shirts made i have a question ?
    This time some short sleeve for those hot days.
    I picked up the new order, and after I got home I noticed the shirts and not 100% cotton they are a blend of polyester and cotton?
    My thoughts are the polyester will melt and not react well to drain cleaners ?
    Any thoughts ?
    Sent From The StoolBus
    www.appletondrainandsewer.com
    Appleton WI, 54915
    1-920-284-7471
    Re: I had a new batch of shirts made i have a question ?
    A splash/sprinkle of Drano on the shirt, I think you're screwed either way.
      Any thoughts ?
      I assume you mean the drain cleaner put in not by you, but by a customer before you got on site. Then charge any wardrobe damage to the customer for using that stuff.
        That would be a good way to lose customers. Also, most of the time you don't notice the damage until hours later or after washing.
          yes customer installed drain cleaner.
          i have gotten drain cleaner on my cotton shirts and had no issue yet.
          but i am curious about what would happen with the poly blend ?
          Appleton WI, 54915
          1-920-284-7471
            What color were these shirts ? I haven't had such luck
              black.
              Ok let me rephrase, you can see some discoloring but the cotton shirt doesn't dissolve or burn to your skin. This is what I don’t want to happen with the poly blend mix new shirts.
              Appleton WI, 54915
              1-920-284-7471
                Mine are a 50/50 blend. I haven't noticed them being any better or worse then 100%.
                  Would it be worth it to get a cheap shop/lab coat for protection on the jobs that your not sure of what was put in before hand to protect your self?
