Caught a big one with the Spartan 300
  • Caught a big one with the Spartan 300
    Don't doubt the Spartan 300 with the .55 cable. Almost 7.5 feet long. Was chocking the whole 4" pipe. Pulled it back on the second attempt, 5 minutes. Went behind with the jetter to clean it up. This was at the city saddle. Looks like its been growing for years.
    Re: Caught a big one with the Spartan 300
    Nice catch. Aren't your saddles 6" in Pasadena? Out here everything from property line out is 6".
    Lots of sweat for 5 minutes on a 74 degree day. Must have been the 60# bosch hammer.
    I see you have a photo crew too.
    Rick.
      Majority of them are 6". I've come across a handful that are 4". 5 minutes of cabling and 90 minutes of the Bosch will surely make you sweat. Jetted it twice last week from another cleanout 100' away and couldn't put a dent in it. Cleaned up nice though today with the jetter.
        Very nice catch but the root mass must have been fairly lose. Although the 300 with the .55mag is an excellent medium duty machine I will not knowingly put it in any 6" line with roots or a root packed 4" line. Bad things can & will happen.
          You must be doing something wrong if bad things happen with your 300. Haven't come across many lines that I couldn't open with it. Never broken a cable. Key to pulling this one out was being close enough to the main roots.
            Nicely done.
            What kind of jetter specs?
            Thanks.
              4000 psi. 9 gpm. 300' x 3/8" hose.
                Been there, done that, moved on.......
                Why fight a root infested line for hours on end with the possibility of getting stuck, breaking or flipping a cable when I can almost always tear it up in no time with my 1.25" cable
                  Sierra, how does that big abs cutter work for you vs a saw?
                    Could you not cable the sewer out from the cleanout 100 feet away?
                    Is the ground out there that hard that you need a jackhammer? The ground looks really dry.
                    Nice catch. Were you surprised? I bet the homeowner was.
                    Roots beware of the C snake with shark teeth.
                      Good for you.
                        ABS cutter makes a nice clean cut. I'm really just a tool whore though. I saw it and had to have it.
                          Tried to cable from hat far away and couldn't do any damage. Homeowner had other guys out and couldn't get it either. Jackhammer cuts down on the digging time. Altadena is full of rocks and hard soil.
                            Should have fed it some 1.25" cable would have saved homeowner a lot of coin & a big mess
                              Good for you.
                              It is what it is..........
