Marco sewer cables difference from standard left hand wound cables
  • Marco sewer cables difference from standard left hand wound cables
    For all Plumbers and Drain people just so you know the difference most
    all sewer cables manufactured as left hand wound. Meaning,
    the more (machine) torque, the tighter the cable draws down, making it that much stronger as goes down into 'a blockage',
    Marco cables, on the other hand are just the opposite: Right hand wound. it is important to know, because when any brand of cable used in their Marco machines it will begin to unwind, uncoil, or kink as it becomes weaker.
    Buyer Beware-
    Many company's are only too happy to sell their brand of left hand wound cable, with Marco fittings, as Marco Replacement cables- now that Marco is no longer around. These same companies are making left-hand wound fittings for these cables!
    Make sure that when you are talking to a sales person, they are selling you actual replacement cables for Marco: "RIGHT" hand wound cables !
    JERRYMAC
    E-MAILJERRYMAC777@GMAIL.COM
    FIRE SPRINKLER CONTRACTOR,
    SINCE JAN. 1989
    Re: Marco sewer cables difference from standard left hand wound cables
    Marco cables will wrap you up .
      Marco drum machines spin counter clockwise ?
        Put my last Marco cable, a 5/16" x 25' hollow core in my K-45AF today.
          Going to run some 3" huh?
            Nah, I use the Ridgid 5/16" wire core on those
              Yes they spin counter clockwise!
              But I forgot to mention that all handgun drill machines 1/4" & 5/16" cables are right hand spun that is why the small Marco cable works in your machine AssTyme,
              everything over 3/8" it makes a difference!
              JERRYMAC
              SINCE JAN. 1989
                General cables in 1/4 and 5/16 sold with there hand guns are left hand wound. The make right hand wound also they are fl left are he. Also marco with older feeds require right hand wound cables these are the ones with the 2 jaw feed and the 3 grooved rollr feeds marvin
