General clog chopper
  • General clog chopper
    Has anyone used this? If so how was the overall experience?
    Pros and cons?
    I would be mainly using this in 4" cast and PVC out to around 150'
    General Pipe Cleaners Cutters
    Thanks.
    Re: General clog chopper
    Here's some past discussions. Good luck.
    https://www.ridgidforum.com/forum/t34671/
    https://www.ridgidforum.com/forum/t36408/
    https://www.ridgidforum.com/forum/t42185/
    https://www.ridgidforum.com/forum/t42668/
      Thanks. The search bar does not work on my device.
          I have the clog chopper in 1 1/2" and also 2" very sharp , ruggerd. Use in top gun and K-375. works great and ruggard
            I use the 1 inch clog chopper on all kitchen sink lines and it has not let me down yet. I have not used any other sizes but would like to get a bigger size to try it on my next house sewer. I believe the design in very good at cutting through "sludge" and grease
              I have the clog choppers in 1, 2, and 3 inch,s . The 1 and 2 have general sloted ends i use the 1 inch with my super vee for soap and sludge bulidup an it works great, but it works best on urine, hard bulidup. I also have adapter for the sloted general end that goes on a ridgid end so i can use with my k-60 and it work great with that setup. The 3 inch chopper is a general/ elec eel one that works great with my drill on tree roots and heavy buildup. They are great heads to have in your arsenal.. Good luck...
                How long have you been using these ?
                  about a year with great results...
