guide hose care
  • guide hose care
    My guide hose was getting really stiff and then finally broke. Here is a picture of the old guide hose(the one that is straight) with the new guide hose. I was using the stiff guide hose so long that when I got the new guide hose I had a hard time hanging on to it because it was so flexible. I will start oiling my guide hose from now on.
    Order guide hose from my local supplier and said it would arrive in four weeks. At the end of four week they said it is on back order. What! Called A. J. Coleman and I had the guide hose the next day. Wow! I know who I am calling when I need a part right away.
    Roots beware of the C snake with shark teeth.
    Re: guide hose care
    What did you use to oil the guide hose with?
    I would think some oils might break it down.
    Let us know how it works out.
      Re: guide hose care
      check your messages
        Re: guide hose care
        [ATTACH=CONFIG]18622[/ATTACH]
        Not just when you need it right away. I learned of a j from here and glad I did. They have good prices and great service.
          Re: guide hose care
          The first few times I used WD-40 waterproof. But I changed over to ultra lube which I found at Lowe's.
          Ultra lube = multi purpose lubricant and penetrant. Plant base oil has 4 times the lubricity of petroleum base oils. More information at www. Ultra-Lube.com.
          I was thinking this might be better than petroleum on the hose. Anybody have any good idea's?
