wiggy
  • wiggy
    Problem = 3" cleanout to 4" pipe that is under the floor then outside of the house is 6" clay pipe. Even
    with a bent cable end it still does not get it cleaned out all the way.
    Answer = Click image for larger version
ID:	636007 I call this wiggy(wiggle). The extra bends help catch the small
    hanging roots that flop around with the cutter. I have used it only a few times but so far I am really liking this. Only used with camera because of the angle of the cutter could get
    stuck in offset.
Name:	30 ft after.jpg
ID:	636009Before and after picture. Notice how clean the pipe walls are. Running water when spinning wiggy splashes water up and washes the walls.
    PS this is not against jetters, this is not against drum machines, this is making the most with what I have.
    Roots beware of the C snake with shark teeth.
    Re: wiggy
    Get the Eel 4"x6" expansion blade you will be very pleased.
      Re: wiggy
      And I was trying to figure out why a thread about a voltage tester would be in the drain cleaning forum and not electrical.
        Re: wiggy
        Can you get this cutter to turn in 3" Tee's and 90's?
