Fun Job
  • Fun Job
    Took me and my guy 5 hrs to chip this out (concrete was laughing at us) and get to a decent part of the pipe. The comby on its back was rotted out. And then another 2 ft or so. The place I cut and tied into was actually very good and better then what I thought I would see being so close. I had to cut out the bottom of the kitchen sink cabinet and hit it with the jackhammer from inside to finish it off. Saved him from having to get the insurance company in on this and tear up a brand new remodeled kitchen with harwood floors. As his only repair is what you see and a new bottom of a cabinet.
    Re: Fun Job
    I though you were going to show us your new nozzle in action.
    or is this a result of using the new nozzle
      Re: Fun Job
      You know what, that is funny.
      What I forgot to mention is the before picture was what the h/o did. I went there last weekend (before bad to the bone nozzle) and coached him on what needed to be done, (he's a friend from church). He called me Friday and said it's to tough and not worth trying to save a couple hundred bucks. I said "a couple hundred bucks?" and started laughing. He said well you know what I mean. So IOW it was before the Hummingbird.
        Re: Fun Job
        You broke a concete footer to make the repair? Hard to tell when looking at the pic on the cell phone.
          Re: Fun Job
          Yeah through a footer,, I screwed up and should have taken the after shot the same angle as the before.
            Re: Fun Job
            If it had been a Crappy kitchen or floor I would've probably gone through the slab in front of the sink and cut into wall and 90 it across bottom of cabinet above slab then down through slab before outside of cabinet. As I have before. But the h/o rolled the dice after I told him its doable and could come out a winner.
              Re: Fun Job
              You're not a plumber, You're a MAGICIAN !! Great work. About the footer. I'm a building Contractor, I've done the same. There is so much strength there, nothing will ever move. You did a great service for that family . Many would have sold an expensive pipe reline !
                Re: Fun Job
                Was that a monolithic slab or stem wall slab? If it was a stem wall, I hope you pinned it...Nice repair, you lucked out there was good pipe down there
                Will Rogers Plumbing
                Moore, Oklahoma
                405) 323-2852
                www.willrogersplumbing.com
                  Re: Fun Job
                  What kind of jackhammer were you using?
                    Re: Fun Job
                    Bosh 11247 roto hammer for me there
                      Re: Fun Job
                      Mono,, actually the camera work showed a good fall after 16 inches, so I thought his chances were good as the rotted out section was under water for 30+ years, and not where I had to tie in to. And he had some very very hard cast to start with. I told him it was a gamble but a good one.
                      Thanks
                        Re: Fun Job
                        Bosch 60pd electric.
                          Re: Fun Job
                          Nice thread ... I am just finishing up a similar one I'll PM you I have a question ... Thanks
