Whats the story on Wet/Dry Concrete Bits?
  • Whats the story on Wet/Dry Concrete Bits?
    Hello gang
    Hope everybodys in good health and spirits
    Please advise on the wet dry concrete bits,,,
    I want a simple way to drill thru 6" concrete block with or without rebar
    If I can drill a 2-1/2" hole with no sweat I'll be happy
    Please advise on ;
    Best bits
    Best drill rig [hole hog or roto hammer? how big?]
    Please advise,,,any help appreciated
    Dave Doyle
    Los Angeles
    Re: Whats the story on Wet/Dry Concrete Bits?
    I have several core drilling machines. Small holes get the hand held rig, although I've done 6" by hand, it's ruff on the machine and operator. Bigger holes get the stand and bolt down.
    I always go wet when I can. Drills fast and cool with no dust, just slurry.
    Typically dry bits wont do real solid concrete, just hollow block. Also most dry bits are high speed angle grinders. Some have a set up for a vacuum cleaner to suck the dust.
    Start with a good handheld unit that can also be adapted to a coreing stand.
    Rick.
      Rick where can I buy the wet dry bits in LA County
      David
        Online is the easiest and least expensive way to buy. You could try whitecap, but they're expensive and selection varies by location.
        Some larger building supply, concrete block, supply houses sell them too. Buy dry bits are typically limited to bock wall and not solid concrete.
        Rick.
