cleanout drain tool
  • cleanout drain tool
    Here is the cleanout drain tool. Instead of the 1.5" valve I went with the 2" valve because I can not image using anything small. After the valve is a 2" flexible discharge hose. I was looking for something a little more rigid but at least this will fold up nice in the van.
    Roots beware of the C snake with shark teeth.
    Re: cleanout drain tool
    Pretty much spot on to what I had described on the original thread. As long as the glove is pretty heavy duty, it shouldn't be an issue. If anyone has a sand blast cabinet, its pretty much the same thing.
    Rick.
      I am sure the glove is strong enough. What I am wondering is how much pressure it will take for the glove to pull out from under the clamps. I used two clamps on the glove.
        Will not pull off. But if there's lots of head pressure, the glove will flip outward / inside out if you remove your hand. Might also want to block the 2" wye port if you allow it too. But its cheap to make and simple to use.
        Rick.
          Here is a handle extender. Easier to do with one hand. But the last little bit you still need two hands.
          I never have liked these plastic valves. I would like to have a brass valve but I did not want to spend over $50 for it.
            I don't have a clue what's that's for ! Will someone explain, please ?
              I personally have only had a handful of caps that I could by hand. What's the plan then? Loosen up with c/o wrench then undo by hand?
                It needs a sign " the Proctologist is in " Yes I'm sick, but You already knew that !
                  This is what started it.
                  Safety Sewer Drain - Making Plumbers Lives Easier More Profit
                    That is the plan uless you have a better idea.
                      That is freaking awesome sauce right there buddy!!!!! Patent that thing lol
                        hey you forgot who posted the idea. that's who owns the rights.
                        Rick.
                          Rick.
                          I have heard of this years ago but forgot about it until you said something about it. Thank you.
                          I will take the rights and you can have the lefts.
                            Boom goes the dynamite! He got you Rick, hahaha
                              Good morning,Please tell me -what is this tool used for?
