Poor cold little jetter needs heat
  • Poor cold little jetter needs heat
    Here in Seattle we have a mild climate compared to a lot of places in the US. We are right by the ocean and we get a lot of rain but the rain keeps the temps up for how far north we are. So I never have to mess with very much in the weatherization of equipment. Sure I let the water out of pumps and shoring and the jetters run them dry etc. I had an emergency to go jet and I had planned on not jetting for a week till this bad weather passed by. Anyway here is a couple pics of using our 350btu heater to thaw out the hose and pump so I could get going. We usually use this heater to heat manholes and foundations prior to lining or coating them. It has 2 12" vent ports and you attach lines to them to direct the heat where you need it, well today I needed it on the pump and hose of my jetter lol. Might need it tomorrow so I filled the pump tonight with windshield cleaning fluid.Click image for larger version
Name:	heater on jetter.jpg
ID:	636049Click image for larger version
Name:	heater on jetter wide view.jpg
ID:	636050Click image for larger version
Name:	heater on jetter both ports.jpg
ID:	636051Click image for larger version
Name:	heater jetter on pump.jpg
    Seattle Drain Service
    Re: Poor cold little jetter needs heat
    Originally posted by Cuda View Post
    Here in Seattle me have a mild climate compared to a lot of places in the US. We are right by the ocean and we get a lot of rain but the rain keeps the temps up for how far north we are. So I never have to mess with very much in the weatherization of equipment. Sure I let the water out of pumps and shoring and the jetters run them dry etc. I had an emergency to go jet and I had planned on not jetting for a week till this bad weather passed by. Anyway here is a couple pics of using our 350btu heater to thaw out the hose and pump so I could get going. We usually use this heater to heat manholes and foundations prior to lining or coating them. It has 2 12" vent ports and you attach lines to them to direct the heat where you need it, well today I needed it on the pump and hose of my jetter lol. Might need it tomorrow so I filled the pump tonight with windshield cleaning fluid.[ATTACH=CONFIG]18722[/ATTACH][ATTACH=CONFIG]18723[/ATTACH][ATTACH=CONFIG]18724[/ATTACH][ATTACH=CONFIG]18725[/ATTACH]
    Good job.
    You got hit with the artic air weather pattern, I did to. It was 46 this morning. The wife wouldn't see me to the door. I hear this weather is going to last like 4 days or so. Oh well, time to man up. Lol
      it was cold this morning. I went to grab my led light and it was real cold sitting in the truck overnight. but I still go out in a t shirt all day.
        In the future use RV antifreeze. The washer fluid has corrosive alcohol.
          -25F here last night. everything gets parked indoors. I used washer fluid for years before I had a heated garage with no problems.
            I do 50% glycol if I know it's going o be outside, followed by a thorough blow down with air
            Still have to bring things in for awhile before an attempt to use it when it's below 0°F
