How I jet
  • How I jet
    812 Cam - YouTube
    So here's a video of todays job. Last time the line has been touched is 7/31/2011. I jetted it today cause the landlord was there and wanted me to do it. The video is real time and the video was never stopped except at the 54' mark. I ran the camera in, went to 54', hit pause turned the jetter and started the video again. 13hp, 4gpm 3500 psi jetter with a root ranger. The roots were light on this one but I do the same process for all my jetting.
    Re: How I jet
    Great job,, so now it's official, you do in fact go forward a few feet instead of back 10 like me. I'm to afraid of marring up a hose. Have you ever had to replace a hose cuz it was screwed up prematurely.
      Re: How I jet
      Nope never, no damage yet, but I spin the root ranger the entire time the foot pedal is pressed. If you're really worried about it, I'd put some christie tape on the first 10'. Keep in mind I was using a root ranger. No idea what a spinning nozzle would do and certainly don't recommend the chain flail with this technique. Made the video cause I hear so often that spinning the root ranger by hand sucks and takes to long and wanted to show plumbers the difficulty is overrated.
        Re: How I jet
        That's true, it's not that big of deal if you know what your doing. I was at the wrong spot it seemed to often when I did it. I get frustrated easily.
        How many inches from the exit part of the root ranger would you say you put it in front of the roots.
          Re: How I jet
          I try for 2" to 5" but you can see in the video. I don't position the nozzle in relation to the roots but focus on the joint. I didn't do anything special for the video. Just did everything like I usually do.
          BTW here's the setup on the ground. The jetter was far away.
            Re: How I jet
            that is pretty dang good.
              Re: How I jet
              I just realized this on yesterdays jetting job although I knew this for awhile. The jetter I used for the video was 3500 psi with a 200' of 1/4 hose so I was only getting maybe 2000 psi at the nozzle. I now have a 3000 psi pump so I'm only getting 1500 psi at the nozzle but am still cutting roots like a champ. Point is....the lower pressure at the nozzle is probably the biggest reason why I never had camera damage. This may not be the best technique if you have higher nozzle pressure.
              BTW.....ordered a new 3/8 jetter with 1/4 ends(ridgid) so I'll only have 300 psi of pressure loss. If I was cutting roots no issues with 1500 psi, 2700 psi will blow them away!
                Re: How I jet
                We tape the front of the Root Ranger to the back of the spring.
                Regards, Bill
                The definition of Insanity: "Doing the same thing over and over expecting a different result."
                Albert Einstein
                  Re: How I jet
                  I've tried that Bill but had no luck. Turning the RR was impossible for me when taped to the camera. However it is a great technique when needing extra push for the camera during an inspection.
                    Re: How I jet
                    Would you post a picture of this please ?
                      Re: How I jet
                      Gear,like several others on this forum,your posts are always very well written.
