K50 drum adapter saved my butt today.
  • K50 drum adapter saved my butt today.
    New customer. Mainline has a big hole in it but that's another story. Got done with the mainline and come upstair to a bath sink not draining. 1-1/2" galvy pipe. Tried my 5/8 cable with every style blade to no avail. The cable isn't coming in. Go back to van and grab my drum adapter. However I switched the front ends. So I used a 5/16" front end with a 3/8 drum. Made so a big difference.....so easy to feed in and out. In any case the 5/16 cable along with my undersink contraption ver 3.0 got it knocked out in about 20 minutes. So glad someone (cough cough mark) introduced me to the K50.
    Re: K50 drum adapter saved my butt today.
    To save room on my truck I no longer carry the k-50,,,,,,,I now carry the k-60 with 5/8" cable and 7/8 cable,,,I wonder if Rick's reverse auger on the 5/8 cable would work?
      Would work Confused.
      It works like amazingly. Easily navigates 2" traps. Have pulled back a couple strainers that were dropped in to the drains.
      Cut off the first few inches of tight wind cable and heat up a loop to make the hook.
      I just made a drill adapter for the 5/8" cable the other day. Pretty easy with a lathe.
      Rick.
        I love the 5/8 cable myself but those 1-1/2" galvanized fitting were just too much.
          Nice You mentioned this Ben. Everyday You guys use a K 50 or 60 say , a lil prayer for brother MarkS good health ! He led Rick by the hand and gave Him a K-50 with training wheels ! Any good artists out there ?
            Rick.
            Could you please tell me some examples of when or where you would use the 5/8" sectional cables with a drill ,and also what model drill do you prefer?
              Not a strong drill, a variable speed even cordless drill is fine. 7.5' can be a bit long if you torque up, but keeping the cable stretched out is the trick. Roof vents with a cordless is the best.a trap could be tricky with too much cable out of the line. Running a reverse auger and drill set to reverse will self feed into the line.
              Rick.
                5/8" cable will NOT pass 1.5" CI drainage 90's, which are basically vent 90's . not even the reverse auger. I have had a hard time getting the reverse auger to pass 45's too. tees are also a pita. I typically use general 1/4" cable for 1.5" lines.
                Ben, you are 100% right about the 3/8 drum being easier to feed 5/16 cable in and out of.
                Got a picture of your "undercounter contraption 3.0"??? very intrigued!
                  Ive used my 7/8'' reverse auger on 1.5'' iron with a 45 to get into a 4'' main on many occasions. now a vent 90, forget about it.
