k-1750
  • k-1750
    What was your solution to the 20 amp plug not fitting a standard receptacle? Just assembled the new one and went to test it today and realized that it wouldn't plug into just any outlet. Just curious.
    Re: k-1750
    cut off the plug and install a 15A replacement. or replace the receptacle with a 20A version (i'd do this).
      Re: k-1750
      you cut the plug and you blow the warranty.
      best bet is to make a 20 amp female x 15 amp male cord adapter. the amperage will spike as the pressure goes up. so watch your self on a 15 amp breaker and outlet.
        Re: k-1750
        That's what I ended up doing. (made an adapter, that is) Thanks.
