1.25" Eel/General Cable...
  • 1.25" Eel/General Cable...
    Have any of you ever flipped an Eel or General 1.25" cable in a 4" line ? What about a 6" line ?
    What was the outcome ?
    Re: 1.25" Eel/General Cable...
    Don't tell me it's possible.
    There goes the dream.
      I seen on another forum what looks to be 1.25" Eel cable that flipped in a 4" line. 6" maybe but I don't see how it's possible in a 4" line ???
        I flipped my 7/8'' in a 4'' line, but it was in the base of a comby. made a big write up on it several years back. even managed to run it 60' downstream and another 10' reverse before I picked up on it.
          Do you think it would be possible with 1.25" Eel type cable ?
            sure did. I wasn't far out from the 4 inch into 6 inch. I was feeding the cable in when I should have been pulling back. heck in the short time Ive been using eel cable I broke 3 heavy duty 4" cutters and 1 thin cutter,
            I come to clear roots not dance with my grandma
              I just don't see it being possible in 4", maybe possible in 6".
              I saw the thread you are talking about.
                4'' pipe impossible. inside a comby, it might be possible, but you'll know right away.
                6'' would be difficult. but easier in a comby or tee.
                  Are you saying you flipped in a 6" line ?
                  Dude, you need to lay off the Wheaties and get a feel for things
                    I use C-14 cable. Going down a 6" cleanout to the main and the cable curled up stream. Cranking on the cable because it was stuck. Never happened before. But the cable had seen to much acid over the years and has become soft. I can not believe the kinds of acid they sell.
                    Roots beware of the C snake with shark teeth.
                      it was in 6 inch. I hit a hard spot but I could still feed the cable in slow so I kept letting it take cable for about 3 feet or more. I figured I should have been pulling back. I don't now why it flipped inside the pipe and not outside. go figure,
                      Sad to say the days of feeling whats going on is gone. If I know I'm in clay I'm pushing that dog for all it's worth, you know what it's like to have every drain 100 foot but mostly more. I've got no time to go easy. I do miss useing the skilsl needed with the drum or K60. it was like bass fishing on 2 pound test line
                        Sad to say the days of feeling whats going on is gone. If I know I'm in clay I'm pushing that dog for all it's worth, you know what it's like to have every drain 100 foot but mostly more. I've got no time to go easy. I do miss using the skills needed with the drum or K60. it was like bass fishing on 2 pound test line
                        Glad I'm not the only one pushing line after line over 100 feet. Just picked up more 1 1/4 so I have just over 200 feet.
                        Just got into the drill so the truck will have more room without the Model "C".
                        Roots beware
                          Were you able to pull your cable out ?
                            I've flipped the 7/8", not the 1.25". I'll never use my j-cable again lol. I'm assuming your talking about me with the resent thread I put up on PZ and on facebook. I did it because I was rushing. I was trying to knock it out quick and work it into my booked up schedule I let my guard down....can happen to all of us. Don't get in a hurry!
                            Will Rogers Plumbing
                            Moore, Oklahoma
                            405) 323-2852
                            www.willrogersplumbing.com
                              [ATTACH=CONFIG]18925[/ATTACH]
                              I saw the Eel type inner core cable and assumed it was the 1.25", sorry Will
