Root Ranger extension
Re: Root Ranger extension
The extension will help slow down the ferociousness of the RR3000 in a 6" pipe but the weight won't stop it doing its job. It's main purpose is to prevent the nozzle from turning around and coming back for you in a 6" and 8" pipe. It also reduces the chance of the nozzle going back up a junction.
See some jetting tips here The Jetters Edge Training & Safety Videos - The Jetters Edge - Jetting Nozzles - Jetting Hose - High Pressure Jetting Nozzles - Mustang Nozzles - Jetting Nozzles - High Pressure Hose.
Or, you could try a Double Barrel Root Ranger nozzle for a bit more excitement?!Regards, Bill
The definition of Insanity: "Doing the same thing over and over expecting a different result."
Albert Einstein
Never used the extension on the 1/4" root ranger. That's because I need to navigate 3 and 4" pipe first before hitting the 6" pipe.
I've used an extension with my 1/2" root ranger on 12" storm drain pipe.
Ben only has 3.5gpm so a double will be a boat anchor for him right now.
Rick.phoebe it is
Ben, do you keep your camera ahead of the root ranger or several feet behind?
If ahead, do you see wear on your camera cable from the root ranger blast?
I made a mistake with the 3/8" warthog letting it run down while my camera was in the line. The carbide wear pads nicked into my camera cable, even though it was a fast pass.
Rick.phoebe it is
Originally posted by PLUMBER RICK View PostBen, do you keep your camera ahead of the root ranger or several feet behind?
Rick.
