Hmmmmm.....
  • Hmmmmm.....
    Only $799.99............. Plus $129.00 shipping.........
    WTH is it ???
    Flexi Cleaner Pro Powerful Coiled Rod Drain Pipe Snake Machine | eBay
    Re: Hmmmmm.....
    Industrial Plumbing, Commercial Plumbing, Plumbing Supplies, Power Drain Cleaner,
    "Close coiled, left hand wound rods are 1" diameter X 25' long. They are easily coupled together for cleaning runs of 200' or more by means of a 5/8" hex nut. All tools are connected to the coiled rod in the same manner. Once the rod and tool are started in the drain, the Flexi-Cleaner is wheeled forward or pulled back which easily pushes or pulls the rod in or out of the line. The 1" coiled rod is at least 4 times stronger than 3/4" cable. Many Flex-Cleaners have been in use for more than 20 years."
    Interesting. Never heard of them before.
      Re: Hmmmmm.....
      Neither has the seller I bet................................
      David
        Re: Hmmmmm.....
        We use to have a couple of their 3/8 drum machines for kitchens.
          Re: Hmmmmm.....
          Their machines have been blue for as long as I can remember. Its a local company out here and some of the supply house carry their product line as its cheaper than most. The build looks like off the shelf parts all welded up.
          Scarry thing is the missing belt guard.
          Rick.
            Re: Hmmmmm.....
            This is a very old flexicleaner with the original lamb motor. It was the best motor used the same motor was used on ridged 400 and 500 threaders with key chuck. Later flexicleaners used other lamb motors that were not as good. Various other motors were used. The new models have 4 wheels and now use a dayton motor. I have not seen a new one. The last good one used a black & decker motor marvin
              Re: Hmmmmm.....
              Looks like a primitive Model C. Probably useless unless its man hole to man hole.
              Will Rogers Plumbing
              Moore, Oklahoma
              405) 323-2852
              www.willrogersplumbing.com
                Re: Hmmmmm.....
                It is a very powerful machine using 1" cables 25' long. There was a adapter to drive 5/16 rods also. The motor is a universal untill the present marvin
                  Re: Hmmmmm.....
                  I believe it is powerful, but how would it ever get through a cleanout?
                  Moore, Oklahoma
                  405) 323-2852
