RV Dump...
  • RV Dump...
    Are these simply trapped and run into a holding tank ? I can only run my rod in several feet before it hangs up on something but I did get it open.
    There are a few deferent kinds some go to a sewer line,some a septic tank, and some around lakes go in to a holding tank. It sounds like this one runs in to a tank and you were hitting the baffle of the tank. The baffle is where most clogs happen so when you hit that it will open. But is it happens again in a short time, have them get someone out to pump the tank. If it is a commercial RV dump it might have a grinder in line before it hits the sewer but you should see the grinder box close to where the dump is.
      What is the electrical conduit in the picture all about?
      • gear junkie
        gear junkie commented
        Editing a comment
        Looks like some electrical conduit.
      • gtmerkley
        gtmerkley commented
        Editing a comment
        Might be a counter to see how meany gallons are dumped. Most places charge by the gallon. When I was pumping septic tanks we had to summit a sample of every load, but they took our word for how meany gallons. the RV dump just used a flat rate.
      • AssTyme
        AssTyme commented
        Editing a comment
        It's a gas station RV dump. You have to enter money/code to get the cover to lift from the inlet pipe.
