K-400 tool set question?
  • K-400 tool set question?
    Hello all-
    I recently purchased a K-400 with a 1/2 inch x 75 ft (C45 Integral Wound Cable). It came with a T-260 tool set as well.
    The "C" cutter that came with it is only 1-3/8" and I was wondering if there is a bigger one for this? I would like the "C" cutter tool to be 3", but I can't find it anywhere! The only one I found was one that doesn't fit the C45 cable. I used to have a cobra drain cleaner that came with a 3" "C" cutter and find that it works fairly well in 4" pipes.
    Thanks,
    yarviinn
    THE 3' CUTTER IS A T-232 2 1/2' is a t-231 MARVIN
      Remember this is not a machine that's designed to cut roots. So unless you have a soft stoppage and sludge, roots can get you in trouble with this machine.
      Rick.
        Not him, the machine lol
