Ridgid T-202 bulb auger broke up in shower drain: How to extract
  • Ridgid T-202 bulb auger broke up in shower drain: How to extract
    I was trying to feed in the line into the drain and I don't know if I forced it and or if perhaps the weld on the cable was compromised but after feeling some resistance I reversed the snake (K-400) and when I pulled the cable out the head had broken off. I don't know I was very far in the drain. These shower drains at work can be a trick to get the Auger, so I suspect and hope that the Auger is only maybe 2 feet in.
    Any suggestions on how to extract it?
    the best method is not to use a bulb auger through a 2'' trap. instead use the Rick Reverse Auger /RRA.
    This is a 5/8'' sectional cable with end cut off and heated to form a small hook. The cable is run in reverse rotation/ counterclockwise. The open winds and flexibility of the 5/8'' cable with RRA end will easily navigate the trap, the hook will grab the bulb auger and wind it further into the sectional cable.
    Problem is you don't have a distance to go fishing for so it might be a little more time consuming.
    Also your 400 machine doesn't run 5/8'' sectional cable.
    Are you in Northern Calif?
    Rick.
      I have never seen a bulb come home yet
      Dont even try a funnel cause you will leave that one in the line too !!
      Use the 5/8 cut off cable on your 400 running in reverse till it finds the bulb and starts to twist , shut off the drum and pull back the cable by hand .
      • PLUMBER RICK
        PLUMBER RICK commented
        Editing a comment
        You're describing the RRA.
        Rick.
      Rick.
      Are you saying the RRA should be used generally through 2'' traps instead of the bulb auger?
      Yes, I'm in the Bay Area.
      I think the Auger broke off early on in the trap. I had difficulty getting the bulb through other drain traps as well (shower traps) so I may be stuck only 2' or so down.
      What about using electrical fish tape?
        Stopped using 5/8" augers and bulbs years ago after breaking 3 in 1 day.
        The Rick Reverse Auger has never broken and gets the job done. It also self feeds as you spin it revese.
        Rick.
          How do I make one?
