FOUND: Drill adapters for 5/8 & 7/8 cables
  • FOUND: Drill adapters for 5/8 & 7/8 cables
    I've been using the "dreel" setup for years and I'm interested in trying the Ridgid sectional cable now too. I found a source for drill adapters that I thought I'd share with you guys.
    The company is Source One Environmental
    https://www.s1eonline.com/buy-now/ca...+Rotator+Shaft
    Here are some pics w part #'s and conversion chart their rep sent me:
    16mm = 5/8
    20mm = 7/8
    (The first 2 #'s in the part # indicate the size)
    These are sold to turn Flex Shaft cables but should work for Ridgid sectionals too. I believe they are Renssi tools.
    I ordered one of each. Cost was just under $60 w shipping. To my door in 24 hours which was nice.
    After receiving these the 5/8 seems to be ok "out of the box" but the 7/8 required a bit of file/grinding (simple) to work. Not sure if this was a defect in the one I got or they all would require a little work??
    Of course you could always fab your own easily as shown here (but I didn't have any 5/8 cables yet, let alone a broken one):
    https://www.ridgidforum.com/forum/me...524#post729524
    Hope this helps you guys who don't have the parts laying around to fab your own.
    Last edited by MainDrain; 01-17-2019, 02:02 PM. Reason: Added pics AGAIN...seems they didn't stay in my post for some reason?
    Thanks that is helpful information David
      Or ... make one out of a twisted up cable for less
        By all means if you have a cable to sacrifice and a welder! I'm all for cheap solutions, I just wanted to provide an "off the shelf" option.
          16mm = 5/8
          20mm = 7/8
          The 5/8" adapter works fine, the 7/8" is not even close will require work.
            Got it to work with some filing and a Dremel.
