Favourite Jetter Nozzles
  • Favourite Jetter Nozzles
    with so many Nozzle's on the market have any drain cleaner's out There got a preference and why
    Tasmanian Plumber living the dream http://kingplumbing.com.au/
    I really like the JetAxe nozzle. Not just because I designed it either. Instead of a rounded nose on the front, it has a head like and axe so it can open up a blockage really quickly. It has a recessed front jet and 6 rear jets at 20 degrees for maximum thrust
    The Grease Ball is kinda cool too! And the Root Ranger, and the Rootex.... now you have me rambling :-)
    Check out some videos here
    JetAxe NozzleClick image for larger version
Name:	Jetex 6R1F side1.jpg
    Regards, Bill
    The definition of Insanity: "Doing the same thing over and over expecting a different result."
    Albert Einstein
      I have a couple of small penetrators and then I follow with the root ranger with so many different nozzles out there I was wondering if any other plumbers had favourites and why, I was thinking about getting a warthog for getting around tight gullies ext
        Where do you even buy the RootRanger?
          https://www.thejettersedge.com.au/on...-nozzle-detail
