Hot watter for drain jetter
  • Hot watter for drain jetter
    Tomorrow I have a Kitchen sink line with lots of grease. the garage door is close by with a water heater. I've never used hot water with My Jetter. Seems like a good idea. What You Say ? Thanks Tool
    You'll destroy the jetter. Cold water only
      Jetters are designed for cold water only... hot water will ruin the pumps seals.. Brother M******* Scott.
        Hot water will typically destroy the packings of the pump.
        The way to use hot water is after the pump. A high pressure boiler is used to heat the water after the pump. Not necessary for a typical 2'' waste line.
        Rick.
          Rick.
          Thanks
            Rick.
            I agree with you brother.
