Sewer Auger for New Plumber
  • Sewer Auger for New Plumber
    Hey guys as the title says I recently started a service plumbing company in Canada, Alberta and I'm looking at adding a main line cleaning solution to my arsenal. I've used Ridgids lineup in the past as an employee when replacement equipment was free, but now that I'm going out on my own I'm looking for advice on a machine that's going to be reliable for clearing between 100-150' including the nastiest of roots. I know the Ridgid name comes at a premium but I'm looking for something that's not going to break the bank of my startup. Any help/info is greatly appreciated! Also if there's a combo kit with a camera setup I'd also be very interested! Not impartial to Ridgid.
    Drum or sectional?
    drum duracable dm 30. It's light enough that it won't kill you going up and down stairs without breaking your back. 120' of 11/16" cable will fit comfortably in the drum. For longer runs you can easily add a 40' or 50' extension from a motorcycle tire.
    For sectional, dreel. Dreel will be your best friend. Loads of info on the dreel set up on this site. Do a search for dreel, eel, hole hawg, and timberwolf.
    ​​​​​​​K60 is ok and will get you by you just have to keep in mind that it's not going to get the really bad roots out of the way very quickly
      You probably want both drum and sectional .. Some drain cleaning members here use RIDGID 7/8" ( K-60 ) cables with a drill ... I use a Dreel setup great for tough root stoppages and mostly a Spartan 300 drum machine or you could use DM30 as Cable or root suggested because of the weight.
      Cable Machines are good for confined spaces or you need to snake a line from a closet flange and sectional setup with a drill is good for roof vents and crawl spaces where a drum machine is not feasible . Best of luck to your startup .
        Agree with the Dreel although150ft with a tough root blockage is asking a lot of a drill. For the longer runs I do have a 1hp Eel (prob only gets used about once a month)
        FWIW: I've given up on the Hawgs. The newer models are crap. I've bought a few at $300 and only get about 9 months out of them. Try the Bosch GBM9-16. They can be found new for as low as $100 on sale (Home Depot about a year ago), currently $129 @ HD & Amazon. I got 2 years out of my last one and it pays for itself after just ONE job! I use mine a few times per day.
        I also carry a Spartan 300(with Eel tool adapter) & K60. The 300 is no 1065 but with multiple passes it can handle most jobs within 75ft. K60 7/8 cable on a cordless drill for vents is a breeze (just be careful if they reduce to 1.5"...LOL)
        *using Eel tool adapter on 300 allows for adding Eel sections if you need a little extra too! (I like using J cables for this)
          That's the same drill I use. Gets the job done
            What is this EEl adapter? What size cables does it connect to on both ends?
              I use 5/8 x 75ft cable in my Spartan 300. They make an adapter that connects to Spartan cable which allows you to connect 1.25" Electric Eel cable/cutters. This makes changing cutters fast and easy. I can also use the same cutters on my drum machine as my sectional (Dreel) setup. I keep a 75ft cable in my 300 drum, this adapter allows you to extend this without having to change drums.
              Sorry, I couldn't (quickly) find a pic to post.
                looks like the SP-43
                  Thanks, I was hoping to find one for the .55 cables.
                    This works for adding the Eel cables to the front side, right? So if you are short and need more cable you would have to pull back the 75' and attach it to the front?
                      Correct.
                      If I have the room I'll run the dreel but in some situations a drum machine may work better (running on carpet or if clean out is in a cabinet and u don't want sectional cables bouncing around for example).
                      Mostly for me its just convenient to have one set of cutters and changing Spartan cutters requires multiple tools and much more time than swapping out an eel cutter.
