Anyone ever found a place to get just the 3" shark tooth blades? I hate having to replace the whole thing for $50.00 when I only need the blades.
3" Shark tooth
What do you need blades for when you have a flex shaft ... Now I remember you have long lines there in Hutchinson ... Plumbers Crib carries the 4 " blades only , in stock and if you order $ 99.00 worth free shipping .
You could try calling AJ Coleman I ordered some Eel replacement blades last year which are almost impossible to find .
Originally posted by All Clear Sewer View PostFlex shaft sucks. That crap don`t like going over 70 feet. We use the C-10 cable with the drill more then anything
Rick
- Likes 1
Well it`s not a Rick wacker for sure. It`s one from pipe lining supply. and it`s complete $hit. after 75 feet. it`s a 3/8 x100 foot and sucks... already burned a hole in it the first month of owning it. Parked in the back room with all the K-60`s and 2 K-7500`s.....lol Drill with C-10 for the winI think they call it a "Rense flex shaft" I call it a joke"
Originally posted by All Clear Sewer View PostAnyone ever found a place to get just the 3" shark tooth blades? I hate having to replace the whole thing for $50.00 when I only need the blades.
The Cable Center has them in stock I just ordered 5. I prefer running the General rotary root saw blades they last much longer and don't bust in half under stress.
Ridgid - 98005 - 3" shark cutter bladeLast edited by SuperSnake; 05-13-2022, 04:18 PM.
Originally posted by drainman scott View PostWhat do you need blades for when you have a flex shaft ... Now I remember you have long lines there in Hutchinson ... Plumbers Crib carries the 4 " blades only , in stock and if you order $ 99.00 worth free shipping .
Flexshaft is high maintenance junk.
- Likes 1
Edit: Forget it, I found some of $16.00 eachLast edited by All Clear Sewer; 05-15-2022, 04:22 PM.
