Pulling a ship out of a bottle with the reverse auger
  • Pulling a ship out of a bottle with the reverse auger
    Not quite a ship, but basically a mop. Had a 3" janitorial sink with American Standard 3" Trap. Sink was plugged solid after recent construction. Lost of sand and grit coming up and I couldn't get the 5/8 sectional through the stoppage with all the debris. Gave up after 30 minutes and decided to cut the vent riser to bypass the trap.
    Drilled a 3/4" hole with a step drill into the 2" gal 1950's pipe. Threaded my 5/8" Rick reverse auger into the hoke powerd by my electric drill and chuck adapter. Hit a solid mass about 5' in, which should be the vertical to horizontal main. Fought it for a minute before it cleared. Now for the fun. As I powered the cable back through the hole, i had a wad of mop strings coming back and couldn't pull them out, even though I had my cable out of the 3/4" hole. Grabbed the leading fibers with pliers and couldn't belive the mass on the first pass.
    Enjoy the photos while you can, as they will be history Jan 4th.
    Rick.
Name:
    3/4" hole i drilled into the 2" gal vent for access to the main.
    Click image for larger version  Name:	 Views:	0 Size:	305.3 KB ID:	754494
    starting to pull out the mop fibers with cable removed.
    Click image for larger version  Name:	 Views:	0 Size:	261.6 KB ID:	754495
    All this from 1 pass with the Rick reverse 5/8" auger.
    Click image for larger version  Name:	 Views:	0 Size:	341.0 KB ID:	754496
    Yes. old 1950s american standard janitoral sink. Seen better days, But now it's draining to see more days.
    ​​​​​​​Building maintenance dept will either cut in a cleanout above the sink at my mark, or put a cork in it to seal the vent opening.
