K-1500
  • K-1500
    I am looking into buying the K-1500, it will be used at a apartment complex.
    What options, do you think I should be looking into?
    thank you
    Bob
    bob, have you used a sectional machine before? do you have experience with drain cleaning?
    the k-1500 is a top of the line heavy duty sectional machine. the only drawback is that you need to connect cables every 15' and this can be time consuming and messy to handle. a k-7500 will do just about the same with less cable handeling and it has an auto feed. it also holds 125' of 3/4'' cable without adding anymore.
      Bob,
      I think the K-1500 would be overkill if it is the only machine you are going to have. I would start with the K-50-8 which will get 99% of everything you will have. If you need to go larger, add a K-60 later on. I would be surprised if you would ever need a K-1500 for an apartment building. Then again I'm not sure what you are trying to clear.
        Thanks, for your help
        Bob
