Electrical safety
  • Electrical safety
    Robert Wilber
    Licensed Philadelphia Electrician
    Philadelphia License # 3516 - 16765
    (LIFE SAFETY WARNING! [disclaimer]
    Electricity is dangerous!
    You can be injured or killed!
    Improper installations can cause fire, injury and death!
    You are more likely to be killed by 110 volts than any other voltage.
    [110 creates the PERFECT fatal current through the human body's electrical resistance!]
    TURN THE POWER OFF WHEN WORKING ON ELECTRICAL WIRING unless absolutely necessary for testing purposes.
    Wear the proper personal protective equipment for the level of risk you are exposed to.
    Licensed Philadelphia electrician
    Philadelphia emergency lighting certification
    Re: Electrical safety
    hello Robert ;
    i think i did ran into you somewhere else in the diffrent fourm.
    anyway i do agree with you 100 percent releated to electrical safety here
    any D.I.Y.'s want to do the electrical work please heed our strict safety and the code as well there are few area may have it own local codes as well but we will try to answer much as can as we can do in safe manner
    a quick info about me:
    I am Master Electrician for Resdentail , Commercal , Industrail and once a while Farm work as well.
    I am located at Northeast part of Wisconsin.
    I am orginally from Paris France
    if you wondering if i have Master Electrician in Paris France ?? The answer is yes i do have both USA and France verison but i will stick with USA codes anyway for majorty of the time
    Merci , Marc
      Marc
      Welcome
      Over in Paris do they have 120 Volt 60 Hertz power around, or is it mostly just 200 Volts and 50 Hertz? I'm thinking for residential service.
        Woussko;
        Unforetealy we still have very few 120v 50 hz service left majorty are 215/400 volts 50 Hz but majorty of the home used the single phase unless have large electric stove or large water heater storage tank type it can bring in 400 volts and the colour code is diffrent what you see in North America system is
        Brown = hot
        Red = hot
        Grey = hot [* i am not sure if that is corret colour they change a bit over the years ]
        Green or Green with yellow stripes = ground aka earth
        Bleu = netural
        for home main service they used any where from 40 to 100 amp depending on size and load .
        [ for larger size it coustmary to bring in 3 phase in anyway ]
        Merci , Marc
          Thanks for the info.
          Over here in the USA (I'm sure you already know this) the colors are as follows.
          Single Phase:
          Line 1: Black
          Line 2: Red
          Neutral: White
          Ground: Green
          Ground can also be bare copper when not in a conduit
          In a 3 phase system
          Line 1: Black
          Line 2: Red
          Line 3: Blue
          Neutral: White
          Ground: Green
          Something I see way to much of is that the conduit is used as ground. If it ever came apart at a joint (happens) then the grounding is lost. I think the code needs to read that in all cases there must be a green ground conductor.
