how deep
  • how deep
    I live in Northern Illinois and neede to bury a wire for a small swimming pool. If I use outdoor wire and put it inside gray plastric pipe how deep does it have to be. It is a 115volt pool pump.
    Please check out my web page
    www.woodandwax.net
    Re: how deep
    Here in New York, regular UF cable should be buried at least 18" deep, not so much for temperature but for the errant shovel or pick axe. If using conduit, either plastic or metal, the depth can be decreased, but that may vary by municipality. I'd check with a local building official.
      Re: how deep
      that is always good advice
      9/11/01, never forget.
        Re: how deep
        In Phoenix and where I live now it is 24" if in PVC conduit or UG cable.. Unless it will be under a permanent fixture like a patio slab or something. I believe it was 12" if it is in ridgid conduit.
        But I am not an expert sparky nor claim to be one. I'd agree with the others above that you check with your local officials.
          Re: how deep
          Use UF cable and go 18", no need to put it in pipe. Sleeve the wire as it exits theground with PVC only at that point to protect the wire when it is exposed. Use a GFI breaker. More than likely if you have a newer pool motor, it will have a twist lock plug on it. Use a Tay-Mac cover on the outlet box or equivelent. But be sure the circuit is GFCI protected. Lou
            Re: how deep
            Hey Guys thanks for all great information. I don't suppose any of you would like to come bury the wire and set up the pool out of the kindness of your hearts.
            www.woodandwax.net
              Re: how deep
              i would but you are 15 miles out of my 1500 mile kindness of your heart raduis. sorry
              lol
                Re: how deep
                lol
                But I am well within that radius, Let me see what I can come up with that needs to be done and I will give you a shout
                  Re: how deep
                  I'll do it! Should I bring my Speedo or can I just borrow yours?
                    Re: how deep
                    I'll loan you both speedos and tanning lotion
                    www.woodandwax.net
                      Re: how deep
                      Ok, you guys are getting weird on us. Where's your self control ???
                        Re: how deep
                        ummmm eww
                          Re: how deep
                          Robert Wilber
                          Licensed Philadelphia Electrician
                          Philadelphia License # 3516 - 16765
                          NEC Table 300.5 Column 4
                          Residential branch circuits rated 120 volts or less with GFI protection and Max overcurrent protection of 20 amps.
                          In trench below 2" of concrete - 6 inches
                          One and two family dwelling driveways and outdoor parking areas for dwelling related purposes only - 12 inches
                          Otherwise - 12 inches [with some exceptions that don't appply here]
                          Always check with the AHJ [Authority having jurisdiction] - you can never be sure WHAT rules they have added themselves. Remember that Code is the minimum
                          Licensed Philadelphia electrician
                          Philadelphia emergency lighting certification
