Turning power off at meter
    Re: Turning power off at meter
    This how I understand it.
    "on agricultural property or rural property", many times you have the meter and the "distribution disconnect", and that is not considered the main service panel, and each building that comes off the distribution point is considered to have it own main panel, not a sub panel. It is my understanding it falls under the NEC 250.32 (B)(2)
    which basically allows for no ground wire being ran if there is not any Parallel grounding return paths,
    (example: I will use my farm, I have a meter pole that is part of my distribution system, some takes off from there to the granaries, and then some goes the opposite direction to a pole that that feeds the house the metal shop, the well, generator shed, the wood shop, a total of 6 buildings, each building is treated as it own and has it own service panel, not sub panels, at the pole there is a utility provided distribution disconnect, not a service disconnect, it is similar as if it was a small community where a number of houses are feed off of one utility transformer, the difference is there is only one metering point, on mine instead of at each building as in the community,
      Your last post is an exact description of what I have.
