4 black/4 white wire from ceiling
  • 4 black/4 white wire from ceiling
    My sister took down a ceiling light. She called me after and here is what I found.
    4 black and 4 white wires. One black wire has a white on the end of the insulation.
    I connected all black and all white to ceiling fan. The fuse blows.
    Where am I going wrong? Thanks.
    http://www.cgiconnection.com/download
    Re: 4 black/4 white wire from ceiling
    Sounds like an older house where many wires come together in a light fixture box on the ceiling. To have 4 whites and 4 blacks, you have 4 separate (2 wire cables) coming into the box. One of the Black/white wires is a switch leg going to the electrical box where the switch was for the light. You have to identify which 2 wire cable goes to the light switch. Once you figure out which wire is going to the switch you will then take the remaining 3 blacks and the white wire going to the switch and connect them all together with a wire nut. Now the power is going down to the switch on the white wire and returning on the black. Take all the white wires remaining and connect all 3 of them together and also connect the white wire from the fan to those whites and wire nut those 4 white wires. Now you have a black wire left coming from the switch, now connect that black wire to the black wire of the fan and wire nut those 2. Now your fan will operate from the old light switch. Try that and report back. Good luck Lou
      WOW. thanks Lou, almost there. Everything works by a switch now(bathroom, kitchen plug, closet) except the bedroom switch. Light works, fan doesn't.
        Got it, It worked. Thanks again, you guys on this forum should have a paypal account or accept credit cards. Maybe I will put a suggestion in.
        Anthony Saya
          Actually, I do have a paypal account......
            Anthony Saya
            if that's the case, i would be a rich man
            this is an all volunteer forum.
            the only one that gets paid is josh, and they don't pay him enough for all that he does
            but finding new local friends and distant contacts is pretty good.
            maybe a ridgid forum get together and tour
              Maybe I will start a business of construction support and just post questions here and make money. You guys could be my middle man.
              Rick, after reading a lot of your replies, you could have a few bucks by now.
                I attempted this same setup and the switch does control the fan/light kit combo BUT when I turn it off the outlets come on (they're off when the switch is in the on position). Any ideas?
                  the simple is you have some thing connected wrong, (I guessing you knew that),
                  most likely your power to the receptacles is being diverted to the light, or your indirectly switching the neutral some how, I can not tell you exactly what is wrong, as I have no idea how you wired it up and what the wires go to, but
                  I would find the hot wire or wires, in the box, Identify them,
                  fine the switch leg, Identify it,
                  and then try to figure out what the other wires go to and do and identify them, and reconnect accordingly,
                  and if you do not have the skill, tools, or understanding to trace out the wires and Identify them, and reconnect them properly, then Hire some qualified, one who can do it properly and safely,
                    I have four black wires and four white wires in an outlet! Yes it's an old house, but there isnt a wall switch, only a pull switch on the light fixture. I'm trying to upgrade the fixture with a light fixture that has a pull switch. All four of the white wires were connected together as were all four of the black wires. One each of the white and black wires was hard connected to the old porcelain fixtures. My thought was to cut and tie off individually the two wires that connected to the old light fixture and to connect the remaining three white wires to the whitewire on the new fixture and similarly for the black. Did I guess correctly?
                      Dont guess on electrical.
                      If you're asking if you can splice the original wires that went down to the original fixture: Yes, provided there is adequate space in the box and you use an appropriate splice.
                      This being an old house could be a problem.
                      Old wiring is probably 60c rated and code requires a 90c temperature rating.
                      The reason for this code is because fires have started when wire insulation melts in box from the heat generated from the fixture.
                      If you read instructions of your new light fixture it says to only use with 90c rated wire.
