receptacle or line issue?
    Re: receptacle or line issue?
    The reason I guessed Murray it is a cheaper version of Siemens that uses an aluminum bus and they melt easier than copper. Siemens builds your panel but I am not familiar with the model in the photos. A square D Homeline Breaker will come close to fitting in a Seimens/Murry/GE but will lock in slightly cocked and it will make a hot spot on the buss as you described. As for a replacement talk to you local electrician, you want something that is supportable in YOUR area.
    Chuck
