Greenlee GT-11 tester
  • Greenlee GT-11 tester
    Well I have no explanation as to why it has taken me so long to buy one of these gadgets!
    Usually I would pull out the good old multimeter and measure to determine if a wire or circuit is live [hot].
    I was watching Holmes on Holmes [Mike Holmes] and he was showing some outrageous wiring and the fact it was exposed and hot.
    I said " I gotta get one of those things"!
    Now I did see the other brands but I like the GT-11 as it uses 2 AAA batteries instead of those dreaded button batteries.
    Ok, here are my questions:
    1. how does this thing work? sensing AC voltage without touching it? I suspect it has
    something to do with near field inductive pick up.
    2. I turned the thing on and rubbed my finger across the yellow plastic tip and the tester
    beeped. I was not sure what happened and did it several times. I am suspecting some
    sort of static field from rubbing the yellow plastic? Or I just have an electrifying
    personality!
    This is a clever tool and should really be in everyone's tool bag.
    Cactus Man
    Re: Greenlee GT-11 tester
    They are a clever tool and have their uses. They sense frequency you can test them usually by running it across your chest.
    They can be unreliable. I have one in my bag and use it to test if a wire is live. Because it does not show as live to a tick tester does not mean it is dead however.
    If I need to work on wiring I never depend on the tick tester to test for voltage. I always use a regular pair of wiggy's.
      The work by sensing the electric field around the circuit.
      I have the Greenlee and 2 others. They are very handy for quick checks, but I usually check the circuit with a tester.
        I prefer a wiggy or a DVM and do a Live-Dead-Live check to make sure the tester or meter is working before I trust my life to it.
          I uses a Fluke pen to do the circuit test...no batteries....beats finding out with my furry little paw I know mines taken a beating and still works...I uses it to do a quick trouble shoot on the line voltage side...voltage here, here and here.....
          Tuesday I picked up a Uei pen voltage detector...detects down to 12 volts...but Im still playing with the sensativity adjustment...too low and it beeps at anything...
            Remodelled my sons bathroom a while back and found out the hard way that the vanity light was switched on the neutral side. Saw that Holmes on Homes show a couple months ago and he was using one of those. Went out and bought one for myself. It does work like a charm.
              Noncontact testers "tic testers" do not replace voltmeters and voltmeter do not replace "tick testers" they are different tools with unique capabilities.
                I have one and love it! Very useful!
