Hi, I have a small trailer thats only 8 feet long. The right tailight and blinker doesnt work. I checked for continuity with a tester 6 inches before light and its good. I also checked for any exposed wires and taped them up in case it was grounding out. The ground, out of plug that I attach to a small bolt on trailer must be working incorrectly cause I cant get it tight but no doubt the ground is touching the metal of trailer just not super tight.
I changed the bulbs, I know its not a fuse cause the left side works.
Any suggestions what else could be wrong? I can replace the wire to that side? I do have a voltage tester but never have used it nor I have I opened it.
So ground? The wires coming in to taillight are 6 inches long, where its soddered to back of each bulb insert. I cant see them but the chance of both bulbs sodders off are slim.
Thanks
Thanks
