Aluminum Conduit
  • Aluminum Conduit
    Can anyone tell me if you need to use a special die to thread aluminum conduit?
    Re: Aluminum Conduit
    I have not threaded much of it, but when I have I did not us any thing special, jsut regular ridgid pipe dies for my 12R or 11R heads . some times on aluminum using ws40 or kerosene helps over oil (at lest on my milling machine).
    http://forums.mikeholt.com/archive/i...p/t-80226.html
    there is another discussion and seems a little more to the point,
    http://www.electriciantalk.com/showthread.php?t=2734 the basic statement is to use new and sharp dies.
    these suppliers say "Threading – Sharp dies and conventional cutting oil should be used."
    http://www.alliedeg.com/pdf/atc_alum_4p_specs_0704.pdf
    http://www.bpmmetals.com/pdf/supplie...%20Conduit.pdf
    this place is the same, some more info on the page
    http://www.shomal.com/products/conduit.htm
