Wire gauge
  • Wire gauge
    Hey there again!
    is it mandatory to use 12/2 wire to hook up with a gfci circuit?
    Thanks!
    Re: Wire gauge
    Not in the states, but I can not answer for Canada.
      Re: Wire gauge
      not unless it is a 20A circuit like for kitchens
      20a circuit = 12 ga minimum
      15A circuit = 14 ga minimum
        Re: Wire gauge
        Originally posted by latexia707 View Post
        Hey there again!
        Thanks!
        I'd personally run 12awg if the device is 20a it'll have a sideways T slot on the left input rather than a verticle slit... run a 20a breaker obviously if you do that... it'll just be able to power larger loads that way is all
        by code if it's intended to run a single appliance I believe it's supposed to be 20a depends on where you are though. I hear some places don't have codes and permits or inspectors...
