Not a neutral
  • Not a neutral
    The "NEC" wants us to use "GROUNDED CONDUCTOR" in place of the outdated phrase "neutral"
    Re: Not a neutral
    Welcome to the forum if nobody's said that yet.
    From your post, I take it you're not too happy with the phraseology required by the NEC. IMHO too many people don't understand the role of the "neutral" in electrical's role. It is a current carrying wire, and most people don't get that. They think since it is bonded to ground in the panel that it's role is duplicating that of the ground wire. I think all the NEC is trying to do is to further specify the role of the neutral wire by calling it the grounded conductor. NEC is a lot like SCOTUS. NEC will do something but not explain why they did it. Same with SCOTUS in their decisions.
    Again, welcome,
    Jim Don
      Re: Not a neutral
      Welcome to the forum. There are times I wish they would change the NEC to where the neutral would only be bonded to ground right at the transformer and no other place. At the point of service entrance you would keep neutral insulated from ground and everywhere you run anything from there a grounding conductor would be required no ifs ands or buts about it. As for the grounding at the service entrance this would be connected to several ground rods near each other and also to your water pipe just before the main shut off valve. In addition a jumper would be required if there's a water meter, water filter or such. And finally a cold water pipe really should not be counted on for grounding anything. People with well water systems in many cases do NOT have a grounded water system unless they make efforts to ground it after any devices including water treatment devices.
      To make this more simple the codes need to be revised and written in more basic English and also have good pictures. Elimination of doubts would be great.
      What everyone must remember is that a grounding conductor is not a return. Except under fault conditions no current is to flow through it. It's there only for safety.
        Re: Not a neutral
        So your saying make it so any person can read it and understand it? Then why would we electricians be needed and why would we be paid what we are if anyone can do it.
        The wording is the way it is to eliminate any doubt. Their are still a few "gray" areas in the code book, but those are becoming increasingly less and less. What few do still remain I believe may intentionally be gray areas. The code book is very specific and worded very intentionally so as to eliminate confusion. If you don't understand the wording, such as grounded conductor vs grounding conductor, you have no business being an electrician at all.
        Jeff
          Re: Not a neutral
          are us plumbers the only ones to have an option to purchase an illustrated code book?
          this takes away most of the confusion and interpretation of the code.
          a good book for an apprentice or journeyman or inspector.
            Re: Not a neutral
            Jeff
            I'm not one. I'm just a big mouthed **** head
              Re: Not a neutral
              Nope, we also have an illustrated version of the National Electrical Code available. I keep a soft bound in my work van and keep the illustrated in my office.
              Jeff
                Re: Not a neutral
                Jeff
                You're, not your.
                There, not their.
                Perhaps if one doesn't understand basic English grammar, he has no business being an electrician...
                  Re: Not a neutral
                  a good discusion on this
                  http://forums.mikeholt.com/showthread.php?t=78067
                    Re: Not a neutral
                    "becoming increasingly less and less"....
                    is that the same as becoming many fewer and fewer?
