daisy-chain electrical outlets
  • daisy-chain electrical outlets
    I want to put three 220V 20A outlets on one circuit, and three 120V 15A split receptacles on another circuit, and mount all the outlets on a stucco wall in my garage to the left of my sub-panel. I want to run THNN wires in EMT and am wondering if I can just daisy-chain the electrical boxes together with EMT as shown below and run the wires through like a raceway. In some case THNN wires would enter and then leave an electrical box without making any connection inside that box.
    [120V]======[220V]======[120V]======[220V]======[120V]======[220V]======[sub-panel]
    I realize I would need to observe the rules concerning quantity and gauge of THNN wire in a given conduit size. I know this can work electrically but I just don't know if it violates the code.
    Looking forward to your feedback,
    Andrew
    Re: daisy-chain electrical outlets
    Are you intending to feed all of the receptacles from one 2 pole 20 Amp breaker or have several breakers?
    One thing you may consider and I'm not sure if your area allows then are special #5842 dual Voltage receptacles. You will need to be careful about wiring them correctly.
    Rating: 20 Amp. 125/250 Volts --- They also come in brown. Leviton (and others) make them for sale in the USA.
      Hi Woussko
      There are two circuits, one for 220V (2 pole 20A), and one for the 120V split (2 pole 15A). I am aware of the receptacles that you have referenced. I actually need to have two 120V circuits and one 220V circuit on that wall in my garage so I can run a shop vac and a router off separate 120V circuits simultaneously or a table saw off 220V.
      Thanks for your suggestion.
      Andrew
        What you want to do is basically just run more than one circuit through a single conduit. Yes that can be done as long as you observe the conduit and box size for the amount of wiring you intend to run.
          I see in the diagram three 120 outlets, making the split from top to bottom in each receptacle. Are the 3 220 volt recepts fed from one breaker, and is there a chance you might use more than one at a time?
          Also since some are 220 and others 120 I would use different style receptacles for each, nothing gets your attention like accidently plugging in a 120 volt router into a 220 volt recept!
            Also since some are 220 and others 120 I would use different style receptacles for each, nothing gets your attention like accidently plugging in a 120 volt router into a 220 volt recept![/quote]
            If you use the correct receptacles, that would be impossible.
