Why all the slots?
  • Why all the slots?
    For the Sparky's, why all the slotted screw connections? Why not more Phillips heads?
    Just makes me wonder when I have to work with one and I'm not that good with a standard screwdriver.
    Thanks.
    Re: Why all the slots?
    no reason
    just the original standard [if it ain't broke...]
    Licensed Philadelphia electrician
    Philadelphia emergency lighting certification
      Thanks RW. Finally a response.
      Don't believe in "if it ain't broke, don't change it" alot of the time. Always should try to improve.
      But maybe I just suck using a Klein slotted also.
        There is probably some fixing. The new outlets also take phillips too, and the Murray panel I got seems to use slotted + some sort of square drive. I think changing the trim screws might look odd though.
          Most panels are slotted or #2 square drive, devices are normally slotted, phillips or #1 square drive.
            " I'm not that good with a standard screwdriver."
            It's to keep plumbers from messing with electrical equipment cause they know plumbers aren't good with slotted stuff.
              I knew someone would get that in. Now what to do about all my electrician buddies I see at the plumbing only supply house.
