Radial arm saw spins slow, hums and trips the breaker
  • Radial arm saw spins slow, hums and trips the breaker
    Hello,
    I have an old craftsman 10" radial arm saw. made by rigid It has a black capacitor. The cap along with a relay are in a plastic box on top of the motor. I cleaned the relay. Still spins slow and trips the breaker. I ordered a new cap from Sears. It arrived but there's a problem.. It's twice the size and three times the MFD... Hooked it up, same problem. the motor just spins really slow and hums. I've cleaned it ... What next... Help please.
    Re: Radial arm saw spins slow, hums and trips the breaker
    bearings,
    loose wire some place,
    or shorted/open or windings, would be my guess,
      ? Where is the start-run windings switch found?
        Another question.. I took the motor apart, the Run/Start winding relay is up near the cap. I clean the contacts and try.. No go still spins slow. I turn the saw on and manually close the relay with a screw driver. This is a weird relay. It has a small coil the is fed by the motor.
        The question. Where can I get one of these. Sears has discontinued them.
        Model 113-29450
        The part number is Sears part number is 63355
        Any suggestions?
          E bay or craigs list, and there are a few other Ebay type of auction places,
          you could try this number on this url,
          http://www.ksl.com/?nid=218&ad=3169818&cat=226&lpid=58
            sounds like a bad motor, have you tried any other appliances on that same outlet??
