Cricuits in Single Conduit
  • Cricuits in Single Conduit
    I support CNC machine tools in a production facility. I have two 480 V 3Ph circuits to run approx 200ft from the electrical panel. One circuit is 70Amp the other 30Amp. Can I run both of these circuits in a single conduit? Taking into account my supposed voltage loss, what would be the best sized conductors for these circuits?
    Re: Cricuits in Single Conduit
    there are many voltage drop calculators on the net,
    http://www.southwire.com/voltagedropcalculator.jsp
    http://www.nooutage.com/vdrop.htm
    and here is a simple to use conduit fill calculator,
    http://www.cerrowire.com/default.aspx?id=49
    some depends on how much voltage drop one is willing to deal with, in that distance,
    and if you do a web search there are many more voltage drop calculators and conduit fill calculators,
    one thing it may be better to use a size larger conduit than jsut the mimum size that will meet codes, for either future needs or jsut to make the pull easier,
