220 baseboard heaters
  • 220 baseboard heaters
    I used 20AMP breaker 12-2 wire wall thermastat everything new & Im new at wiring going by B. & D. book. When I turn on my heater the electric meter outside goes wild(run very fast) any ideal why this could happen?
    Re: 220 baseboard heaters
    Ok first off, baseboard heaters use up alot of juice, so yeah, they do make those meters spin off thier gears don't they? :}
    Anyway. For the heaters, how long are they, and what are thier rated wattage? Assuming standard 240 volt household voltage of course.
      the simple is, resistance heat takes a lot of power, and the meter spins when you use a lot of power,
        Wait till you get your electric bill !!!!! Hee Hee
          The guy probably has one of those old 100 amp meters too.
