Question about flat panel tv installation
  • Question about flat panel tv installation
    I mounted a flat panel tv in my home office, and didn't want a mass of cords dangling from it, so I put in 2 low voltage wire pass through wall plates and put the HDMI and other video cables through them.
    My question is what to do about the power cord? do I violate code if I put the tv's power cord behind the wall with the video cables? Will I ultimately have to put in an outlet directly behind my tv to meet code?
    Right now, the "cord spaghetti" looks a lot better with most of it routed through the wall, just not sure what to do with the tv power cord now
    Re: Question about flat panel tv installation
    You can not run the power cord into the wall and back out again.
    You need to put a receptacle behind the tv.
      like jbfan said no u can not run power cord in the wall. Is there a receptacle under the tv now? If so an electrician should be able to cut one in up higher on the wall behind the tv.
        yeah, there is, it's just 1 stud over to the left side.
