How much power is needed here?
  • How much power is needed here?
    I'm trying to figure out what size fused enclosed safety switch and what Amp fuses are needed for this. Below is the info I have to work with.
    Volts: 230
    Watts: 50,000
    Phase: 3 delta
    This is for a boiler in a commercial building. Please remember this is a three phase setup. Also, being resistive heating elements I don't see where we need to get into power factor and the like. Figure on unity 0.0 power factor, please.
    I need to know the Ampere draw and the correct fused safety switch and fuses to use for this. Remember this will be in use 24/7 and the boiler will see a heavy load so the elements will be pretty much a continuous load.
    The boiler wiring will be 3 conductors with ground. L1, L2, L3 and ground. There is no need to think about a control circuit. Everything is self contained as far as controls go. It is a hot water and not a steam boiler for what that matters.
    Re: How much power is needed here?
    Ohms law= Watts devided by volts= 218amps.
      218 A is correct for line current but phase current will be 218 / √3 =125.8 A, add the saftey factor of 125% and you have 157.3 A
      I believe the next common size of breaker is 175A so the wire size would be 00.
        Phase and line current have always thrown me off.
          But we need to remember this is 3 phase power we are dealing.
            60a
              wbrooks's has it
              50,000 divided by 230 divided by 1.732
