panel wiring
  • panel wiring
    I have inherited an unfinished garage sub panel installation. It is ran to an attached garage 50' from the main house panel. A 100 amp double pole feeds triple 2 Al to a QO sub. The neutral is not bonded at the sub. One wire with a red stripe is on what looks like the hot. The other wire is on the opposite lug. The bare is on what looks like the neutral lug. There is a ground bus screwed in the panel as well with nothing on it. The feeder wire is only three wires. What should be the next step, starting over or finishing a pretty good idea. The house has 200 amp service in a Cutler panel. Both insulated wires are on the feed breaker and the bare is on the ground bus in the main panel. Any info is appreciated.
    Re: panel wiring
    If the area is under the 2008 electric code, then you need to start over and install 4 wires to the garage.
    You also need to install 2 ground rods.
    If the area requires a license to do electrical work, I would turn this over to an electrician.
      Re: panel wiring
      2 ground rods for a 100 amp sub panel?
      To original poster call a electrican.
        Re: panel wiring
        According to the 2008 code, you bet. Any sub panel to a detached structure as a matter of fact.
          Re: panel wiring
          May have to get someone who knows what theyre doing. Its been a head scratcher wondering what to do and why its the way it is. Im giving points for effort though. As far as I know no juice has been thrown to it (thankfully). The house was built in the mid 80s. No electric problems thus far everything else seems to be good. All except this sub installation. The more I think about the potential i do want to pursue finishing what was started, as correctly as possible.
            Re: panel wiring
            Does no one do a resistance to ground test anymore before pounding in a second and normally uncalled for rod? Does anyone even know what megger test equipment is?
              Re: panel wiring
              Call an electritian, because you do not know what you have or what to do with it.
                Re: panel wiring
                Come on guys, the OP said it is an attached garage so what's with the ground rods? OP, first off, What type of wire feeds this panel? Is it armored BX type cable? If so you do not need to change the wire. If it is some kind of wire without a bond then you need something to make a bond. I have not seen wire without a bond in many years. If you have 4 wires black, red, white, and a bond you are OK. If you have 3 wires in a metal jacket, you are OK. I assume since you have 3 wires you have armored cable. If that is the case connect black and red wires to the main lugs in the subpanel. Connect the white wire to the nuetral lug. REMOVE OR DO NOT USE THE BONDING SCREW. Be sure you have a good connector on the entrace cable to the metal box and its secure. When wiring into the panel (if you use Romex) put the bonds on the grounding (bonding) bar and not the nuetral bad. You said the panel had a seperate bonding bar. That's it
                  Re: panel wiring
                  Nope. I guess you are the only one.
                  Do you have the $1200 tester required to do ground rod resistance? I don't, but at the same time I rarely get asked about the resistance or a second rod.
                  For those who get asked and are required to show resistance numbers a second rod is just easier.
                  I personally don't stress over a second rod because they don't do very much to begin with.
                  Also, if you are doing ground rod resistance with a megger you are doing it wrong anyway.
                    Re: panel wiring
                    Oops! I may have misread the OP's post. At first, it looked like he was completing a sub panel installation from an unfinished garage to an attached garage. I assumed two different structures. If he is doing as QROKING suggests, i.e. completing an unfinished sub panel in an attached garage then QROKING is correct. If the OP had said "I have inherited an unfinished sub panel in an attached garage", his statement would have been clearer. Sorry if I misinformed anyone.
                      Re: panel wiring
                      That is assuming the second rod is gonna give you 25 ohms of resistance. A side note Megger is the brand name, although most guys just call it megger test equipment when there's actually all different products they make.
                        Re: panel wiring
                        Then I suggest you go back and read this section of the code. The 25 ohms is a non-issue once you sink the second rod. With two rods the 25 ohm requirement goes out the window.
                        Ummm...yeah. I know.
                        My "megger" is made by Amprobe.
                          Re: panel wiring
                          Thanks for the verbal schematic QROKING. The feeder is Al triple 2 with two insulated and one bare wrapped around the others. I twisted the bare together to get the third wire. I mounted the box in the wall and fed the wire through. It was just sitting in the hole they cut. The wire appears to be service wire. The grounding bar was laying in the box and i screwed it into the box. All wires that will go in it will be Romex. This wouldve been easier with a 4 wire feeder, but i cant complain. The box will only power lights, outlets and an opener. It looks like it will work, from information i have gathered it looks like it will. I will go ahead and put a ground rod in. Does it have to be a certain distance or place? Is it the bare 8 Cu? The green bonding screw is missing after the last cleaning anyway good thing i wont need it. thanks
                            Re: panel wiring
                            The way I read this original post your plan is all wrong. IF this is an attached garage as it seems then you CANNOT use the 3-wire feeder as you suggest, and NO ground rod is needed or wanted.
                            For a sub-panel in an attached garage or other area a 4-wire feeder is MANDATORY.
                            Can you please clarify that it is either a detached garage or attached?
                              Re: panel wiring
                              To hell with a second ground rod, go full-bore and install a grounding ring around the facility, and "cad-weld" the number 4 copper to each ground rod and joint. Then take a picture of the inspector's face when he shows up on the job. Your work will never be questioned again!
