2-3/4" Chassis Punch
  • 2-3/4" Chassis Punch
    Does anyone know where I can purchase a good chassis punch to make 2-3/4" holes? When I say 2-3/4" I mean that I really want hole to be 2-3/4" diameter. I'm sure such is made as it's the correct size for mounting many panel meters. For now I use a hole saw and a slow spindle speed drill press (16 ga. aluminum sheets and 150 RPM), but can't get as clean a hole as a good punch would make.
    While I'm sure for enough big $$$ Greenlee would make me a special punch, I bet somewhere I can get one ready made up. I don't mind grunting away turning a screw with socket and ratchet wrench. That means it doesn't need to be for a hydraulic punching setup.
    Re: 2-3/4" Chassis Punch
    have you watched Ebay,
    they at one time were a bunch of old radio type chassis punches when I was looking for come conduit punches, (no sure of the sizes but nearly ever type would show up from time to time),
      I used to look and need to keep watching eBay. I'm pretty sure Greenlee has made and may still make that size, but new it would be good money for sure.
        page 2274 in the McMaster-Carr catalog on line part#3449A124 $226.81
          I did measure the hole the 2 1/2" conduit one of mine would cut and it is 2 7/8" hole,
          I just thought I would check to see what it was,
          GRE730BB-2-3/4 - Greenlee 730bb-2-3/4 2-3/4" Radio Chassis Punch 203.91
          http://www.blackbookoftools.com/Prod...roductID=21200
            Thanks everyone for your help. Please note that Woussko is cheap and most likely will stay to using my trusty hole saw. If I need to make lots of 2-3/4" holes then maybe I'll get a good punch. I'm also going to ask around local machine shops if they happen to have a 2-3/4" punch. It might be better for me to take the work to them and have them punch the holes for me.
