Flourescent Light Ballast
  • Flourescent Light Ballast
    Can a Flourescent Light Ballast be tested?
    Re: Flourescent Light Ballast
    Replace the suspect ballast.
    If the light now works, then it was bad.
      I might have time to head to Fla. with a sharp pointed boot. You got any hemorrhoids?
      Free time for you I see.
        You know what they say about idle minds.
          Used to, but the last hillbilly I messed with stomped a
          mudhole in my azz, then turned around and stomped it dry.
            It was the ballast. Just replaced the whole fixture assembly.
              There is an Actual way to test a Ballast. You would want to check the voltage across the ballast. The voltage across it will be very low while the starters are operating. After the flurocent gas starts to conduct. The Voltage will Increase.
                touch it to your tongue. breid........
                  We live in an age of "swap-tronics" , if a flourescent fixture no longer works, change the ballast with a new one, it is that simple.
                    jc
                    yes. breid............
